MJL944
Gents,
Your advice/wisdom please.
My 1989 944S2 suddenly spat out about 3 tablespoons or so of coolant through the small overflow pipe just under the coolant expansion tank cap. This happened last night, right at the end of the car's weekly 1 hour run-out and seemingly as soon as I switched the engine off.
I touched all the coolant hoses and they were all the usual hot temp except for the small coolant pipe that runs from what I understand to be the water pump 'elbow' joint, and which travels up and level with the top of the radiator, then goes under the AFM before coming to a T-junction just under the expansion tank. The cool section of pipe I'm referring to is the long section of the pipe shown here (thanks to Woolies website) > link to pic of coolant pipe
The long section of that coolant pipe was only mildly warm at best (especially in the middle) so it looks as though coolant flow through that section is suddenly pretty none existent. The last time I touched that section of coolant pipe (to reseat one of the slightly broken plastic clips that holds the pipe in place correctly) was only a couple of months ago and the pipe was red hot then as usual.
A new water pump (a genuine Porsche part and eye-wateringly expensive!) and thermostat were fitted by a local indy 12 months ago and I've had no noticeable issues since other than there was a sudden slight coolant leak back in January from the tiny coolant pipe that leads from the top corner of the radiator directly to the expansion tank (it joins the rad just above the radiator top hose) and this was sorted by my local OPC. I did notice that that small pipe was cool as well last night.
Any thoughts as to the issue?
Is it possible that it's just some air in the system as this pipe is just about the highest point of the coolant system (although the pipes through the throttle body seem about the same level and they were hot)?
If it's just air how has this happened and is it just a matter of performing a quick bleed?
Might some debris that's been lurking somewhere for the past few moths have suddenly shifted to cause a blockage (maybe something disturbed by last years water pump change or the replacement of the plastic bracket for the small coolant pipe changed by the OPC)?
Or, (shudder!), is this water pump related?
Any thoughts appreciated so I can decide whether to call the local Indy (who fitted the new pump) or my (more convenient) OPC to investigate.
Thank you.
Mark
Thank you.
Mark
