Gavinhousley1961
Hello
I have a 2001 facelift Carrera 4 and I'm having problems with th psm and abs light on all the time. I changed front wheel bearing removing the complete hub assembly then when reassembled lights cam straight on. The things I've done. Plugged in Porsche scanning tool and code 4025 front left wheel speed sensor wire. New speed sensor lloghts still on. Repaired wire harness lights still on. Any advice would be really helpful. Thank you. Gavin.
