981 Spyder adjustable aftermarket suspension ???
Bispal
Has anyone put adjustable aftermarket suspension on a 981 Spyder to improve the ride on the road, such as Bilstein B16 PSS10 / KW Variant 3 / Ohlins or ??? I want to be able to soften the ride when used around pot holed UK towns and rough B roads! The Spyder suspension is unfortunately non-adjustable :-(
No one mods cars in the UK esp rarer cars sadley.
You will also find KW and Ohlins have triple the spring rates so make things worse,.
Maybe it's just the wrong car to own and you are better off with a 981 GTS with PASM and £10k in your pocket and a working roof.
