Waylander
Active member
So tonight in a couple of hours I have stripped the front of the engine bay out
The rad and all the bits the front engine covers the trays and started to change all the old hoses for silicone ones blue silicone ones not sure I like it much.
Changing the belts but not pump or rollers this time but can see a seeping leak from the water pump, so that got to come off and a new gasket also the hoses go under the inlet manifold so that's coming off too
Going to be busy for the next few evenings
Also made up an injector cleaner with a PP3 battery some hose, a couple of big cans of carb cleaner should be a bit of fun
