Travelling up the M5 in the Macan SD this week, the CEL suddenly came on and the glow plug light started flashing away. A few miles later the car went into limp mode. [
Luckily enough, being only a few miles from Bristol PC, I called in and they cleared the codes for me, reset the ECU and I was able to complete my journey without further ado.
Back home yesterday, I spoke to Exeter PC, who kindly offered to check the car over ahead of the Macan expedition next weekend since I didn't relish being recovered from the wilds of North Wales to North Devon on the back of a trailer! [&:]
Taking a look and plugging in the box of tricks, they could find nothing much wrong. However the suggestion is, it may have been an error caused by regeneration of the particulate filter. The vehicle does lots of short journeys and the exhaust system more likely than not gets a little choked up.
The tendency then is for the system to overheat slightly on longer journeys as it tries to burn off the excess soot and this produces an error code. Sounds like a plausible explanation to me.
I am told, if there's a repetition of the problem, to pull over, switch off and withdraw the ignition key, wait a few minutes then restart and hopefully the problem will be resolved. We shall see!
So far I have travelled a further 500 miles with no reoccurrence - so fingers crossed! ????
