I have a headlight working problem
The only thing on the wiring on the switch that doesn't tie up to the Bentley book is the yellow wire from the stalk with a large white connector on which is connected onto No 56 on the switch White / Black stripe. Surely if is was going to fit there it would have had a standard female spade connector like the other connections from the stalk
As i already have a yellow wire with wit ha male white connector floating around doing nothing as well I think this is the cause of no live feed to the fuseboard on yellow.
Could anyone confirm the position of the 2 yellow wires with male & female connectors on please
Alan
