remote key fob issue after replacing battery
majordom
porsche 911 996 targa 2002
i have 2 keys with remote fobs (3 buttons on the targa) - both are used regularly
on one of them the battery ran out - the red led flashed but very faint and the remote did not unlock the car
i replaced the battery (i have done this before successfully) and now when i press to unlock then the red led on the fob
lights up bright but just once (rather than rapid flash) and does not unlock the car
any ideas ?
thanks - the key itself works fine its just the remote fob
Porsche did a technical bulletin about replacing the key battery, and re-starting the processor by reversing the coin cell. Here it is, but I have to say that I have only heard of it fixing the problem a couple of times.
Download
hi, had similar problem, did everything, even wasted 70 pounds refurb the key, only answer, new fob and resinc in porsche , dont waste time and money like me. regards elwyn
Sounds like the battery didn't run out and more likely the fob just died as they do all too often (thanks Porsche)
Lots of Boxster owners have just bought after market central locking units and wired into the doors contacts as a way of having a reliable cheap fob replacement.
Brief write up here and the kits normally tell you where to splice into:
Posted December 11, 2010 (edited)
MY97 Australian delivered car. Has driver side and passenger side keyholes. Has central locking. No remote. No alarm.
I just installed an aftermarket alarm/remote/proximity entry unit. I will write up a DIY if there is enough interest but I believe most people from the US would have the remote feature as standard. Come to think of it, there is probably not much to write. Everything you need to know is below:
1. Everything can be hooked up under the passenger seat (RHD car) except the ACC ON signal, so remove the seat first (4 screws)
2. A Bentley manual or a wiring diagram from the factory manual is an absolute must, and contains all the necessary information to figure out which wires to splice into.
3. The door motors are negatively triggered
4. The door open trigger is labelled "door contact" on the wiring diagrams. I am unsure the difference between this and "door safe" - which also appear on the wiring diagram.
5. The door open signal is negatively triggered.
6. There is a separate trigger for "door contact" (door open) for each door, and there appears to be no combined signal. You might need an additional relay if you want your alarm unit to be triggered when either door is opened.
7. Unlock signal is labelled "unprime", and a single connection would unlock both doors.
8. A single lock signal would lock both doors.
9. The wire colours for a RHD car are: Red/Brown (thick) = 12V, Brown/Red (thin) = motor to open door, Brown/White = motor to close door, Brown/Green = (RHD) driver door status (closed), or LHD passenger door status; Turn signals = Black/White, Black/Green
10. Don't splice into the dash central locking switch (inside handle not secured), use the direct connections to the motors above
Credit to Jinster @ Rentech
https://www.renntech.org/forums/topic/36144-remote-central-locking-install/?_fromLogin=1 (you'll have to login to view)
Excample of the kit
https://www.aliexpress.com/item/Viecar-Car-Remote-Central-Door-Lock-Keyless-System-Central-Locking-with-Car-Alarm-Systems-Auto-Remote/32969027039.html?spm=2114.search0604.3.1.2c836f189fHir0&s=p&ws_ab_test=searchweb0_0,searchweb201602_2_10065_10068_10130_10547_319_317_10548_10696_10192_10190_453_10084_454_10083_10618_431_10307_10820_10301_10821_10303_537_536_10059_10884_10887_100031_321_322_10103,searchweb201603_2,ppcSwitch_0&algo_expid=b83073cc-57fd-4a02-8705-6c3a56874217-0&algo_pvid=b83073cc-57fd-4a02-8705-6c3a56874217&transAbTest=ae803_3
Remember this is not over riding the OEM alarm system its just utilising your RFid pill for the immobiliser and energising your door locks.
There are more detailed posts around if you search.
Richard.
thanks everyone - i still have one key fob working so will stick with that for the moment
related question - what are the consequences of not using the remote fob - ie just opening and locking
with the key ?
with the key ?
None, it will be fine just no alarm.
And that will help save the battery too, as it's not running the sensors if it is just locked :)
Hello to everybody I can help I can learn used key fob for all 996 986 ,I need only PAS unit and key fob (old without code) ,or you can ship me your old key fob and I can read 24 character code from each remote control.
Regards for more info contact me on smuko@brizzard.net I'm from Slovakia Bratislava
Ok ,how much cost key (key without code which doesn't work) ,Tell me, 50 or 100 euro? I pay forward on your paypal account ,ok?After reciept payment you ship key to me .
This is maximum what I can do for start this project for other members here.
regards
Just tried it. It worked for me!
Reversing the polarity of the battery for 3 seconds, then inserting it properly did the trick.
Hi there
I’m having a similar key fob issue with one of my r/c’s.
The fob was slowly getting to the point that I needed to be closer to the car until it stopped working altogether.
I changed the battery as I’ve done before and now it doesn’t work at all. LED lights brightly when pushing buttons as it should. Key works fine in the door.
Have tried re-booting the processor per Porsche technical guide found in forum but not made a difference.
In addition to the above I am now using my 2nd key r/c which unfortunately isn’t saving the memory seat position despite trying several times including clearing the key memory first as per the instructions in the manual. Instead it moves the seat right bank when I unlock the car with this key.
So now left with 1 r/c that doesn’t unlock the car and the other r/c that does but moves the seat to an incorrect position when so doing.
Any ideas to resolve both issues would really be appreciated...
