What is it ?
- Thread starter Frenchy
vitesse
Active member
Frenchy said:That sounds about right though my car (88 Turbo) does not have the carbon canister set up so guess it feeds (recirculates) via the throttle body until warm ..........sounds plausible ?
Hi Jim
I'm not totally sure what the vac line to the throttle body does, or should I say I can't remember. I don't think it has anything to do with the carbon canister. If I manage to remember tomorrow, I'll ask my son, he may be able to give an answer. You say that your car doesn't have the canister, did you remove it? I thought they all had this system. Also if you don't have it, where has the fuel vent hose that comes from the tank gone too...it's a metal pipe fixed to the bulkhead, usually this would have a flexible hose that goes to the vac diaphragm system sitting on top of the passenger inner wing which then goes through the wing to the cannister. I run a hose from that pipe down the driver's wing under the windscreen washer bottle and fitted a filter on the end, put it as low as possible to stop the smell of fuel inside the cab
Kongsodoken
Frenchy said:Nope no carbon canister on later cars Pete, my 86 had this but not my 88, my mate's 89 does not have it also, not sure where the vent hose from the fuel tank is, but I am sure it will be vented.
My 1991 has the carbon canister[8|]
