Poor running S2
- Thread starter russmw
colin944
Active member
Restarted the car and drove off to go and meet with some pcgb members about 50 miles away. The car was having a problem idling and would almost stop then catch and hunt a bit.
Any drive onto the motorway and cruised at a nice steady pace 70 Ish mph.
Pulled off the motorway and drove down to the hotel. The car appeared to die like it wasn’t getting any fuel. I managed to get it to start by jumping it In gear. I struggled to the hotel. The car wouldn’t run. It would start and Rev and die as soon as you let the throttle off.
Managed to get it to start and drive home. It cut every time I lifted off the throttle and would lurch and kangaroo when held at constant throttle.
Back firing coughing and spluttering. feels like it’s not running smoothly at all. Maybe missing a bit as well. Also smoking. Tail pipe is black.
Changed DME relay. No difference.
Noticed wiring to hall sensor in distributer looks baldly chaffed.
Any ideas
robwright
colin944
Active member
Fuel filter not in backwards. The fitting on the out side of the filter was not sealing properly. Not leaking or weeping just not sitting quite right. Played around with the fittings on the filter and got it to seal properly. Started the car and it ran pretty well. Holding an idle etc. Raving with a bit of smoke but no where near as much as before. Then the idle went and the car started hunting again and smoking when I reved it. Pulled the plugs. All really sooty. Changed them for a good set I had lying around. Car started but still wouldn’t idle very well. Switched it of and fiddled with the wiring and plug in the hall sensor on the distributor. Wires are badly chaffed and a bit melted. Wiggled the wires around started car and it ran beautifully.
Ok. So unplugged the sensor and car continues to run smoothly. Plugged it back in and car is running really well. So next thing is to clean up and fix the bad wiring at the sensor.
But why did it still run with the sensor unplugged ? I always thought that’s what sends the pulse signal to the coil for the spark.
Waylander
with no signal from the sensor the ECU reverts to all at the same time to activate the injectors, when its working they fire off sequentialy
also with no signal it retards the ignition timing 5-10 degrees
the plugs can be replaced
i got mine from a place called brandshatch performance, they are three pin junior timer plugs
