I know on the 987 there is a pipe inside the car that comes off and cause water inside the front passenger car from the air con
What causes this on a 986. There is no water by the battery
Where are the drain holes at the rear
about 3 pints of water was in the passenger rear footwell.
THe front of the passenger is dry
and so are both Drivers side wells
And what is the unit that is here (I think it is the ECU)
THere is a spare wire by this unit that is not attached
