Purpose of ring pull by drivers side door and inner wing
gedburke3
Dear all,
Whilst giving the car a good clean today I noticed a ring pull which is attached to a cable that lives between the drivers side door and the inner wing.
Can anyone tell me its purpose, there's no mention of it in the manual.
I think I have attached a photograph to show it.
Kind regards
Gerry
I’ve got one of those. I think it let’s you open the frunk if the battery is flat but hopefully Richard or a n other expert will be along soon to confirm or deny.
There is one at the rear, behind the rear lights, for the engine compartment to be open in case of flat battery (but you have to have the engine open, to get to the screws to remover the lights, but hey), so would assume, as above, this is the same thing for the front :)
Hi all,
My fuel filler cover locks and unlocks with the central locking.
I'm assuming that this lever allows you to override that if the central locking packs up or the battery dies?
Gerry
Cheers Andy,
Are there any other levers etc hidden away on a 996 that perform similar functions?
Are there pull levers to release the bonnet and boot in the event that the central locking fails?
So many questions but I do appreciate your help.
Gerry
The emergency engine compartment cable pull is located under the nearside rear light cluster, you should be able to hook it out through the small gap under the rear light.
Hi Andy,
I wasn't aware of either of these. Many thanks for the time you have taken to show these and add pictures, i appreciate it.
Gerry
If you have electric release on the front lid, the emergency pull is on the driver's side. If it is has mechanical release, it is on the passenger side. In both cases, the rear lid emergency pull is on the passenger side behind the rear light. (RHD).
There, that's told everyone how to break in to a 996! Of course, the alarm will go off if it is locked.
Not forgetting that if the battery is flat and the car is unlocked you can release the front bonnet by detaching the internal aluminium lever release unit by the drivers side door by undoing the screws which gains access to manually release the bonnet. This saves jacking the car up, releasing the wheel and removing the wheel arch lining.
Does this work for a UK 997 with electric trunk release, what is the aluminium section you are referring to please?
On the 996 if flat battery unlock car with key you can use slave battery to release frunk and engine cover, jump leads to footwell fuse box special connecter in there that you pull out ,and other jump cable to drivers door frame latch.then elec release buttons will work as normal
Jhardy said:
Richard, do you know if that is the same for a UK 997, i.e. drivers side please?
On the 997 the emergency front lid release is in a different place. Passenger side, behind the wheel arch liner, near the front, and lower down.
