Porsche Injectors - Part No. 93060612000
Beaky
Anyone found as compatible injector to replace the above.
These are now £200 plus VAT each from OCP and the Bosch equivalent - Bosch 0280150158 has been withdraw from the market at Porsche's request I'm told!
There‘s probably not a lot wrong with them, usually they just need a clean and test. This company does a reconditioning service.
https://www.fuelinjectorclinic.co.uk/
Got them done on my 3.2 Carrera by a local company who use the same machine, they came back looking like new and no problems
New one fitted, sounds and runs even smoother through all the rev range - safe to say new injectors should be factored into a rebuild
Redid mine with fresh o-rings pintles and filters and used an ebay injector cleaner kit and carb cleaner. Total cost was under £35 and took about 2 hours - result was a significantly smoother happier car and wish I'd done it ages ago as two of the injectors were pretty gummed up.
Injector parts were from cp fuel injection on Ebay "Porsche 6 cylinder Bosch Fuel Injector service/repair Kit CP-K0C6" and the cleaner was one of those universal kits
