Awkwardness of a simple task challenge.....
scam75
  • Status: online
scam75 Guest of the Club
2018/08/03 19:59:33 (permalink)
Evening all
Set out tonight to do a few little jobs. Nip up a wheel bearing, no dramas, tighten alternator belt a little. Other than the faff of taking off all the turbo undertrays, no dramas. Always thought there should be some way of changing or tensioning the front belts without that carry on but never mind. Then I went to do what I thought would be a simple task of installing an alternator cooling pipe. Mine has been MIA for god knows how long. Only 20 odd quid from OPC and it can't hurt the alternator to get cool air. Cue the most awkward place ever to get the new pipe on and do up the jubilee clip! Obviously the easy way to do this is with the alternator loosened off and the shroud off then it would be a canter but at 4 hours work start to finish on a turbo gave that a body swerve. Ended up like a game of twister that was finally solved by much swearing, a 7mm socket, a 1/4 inch knuckle, a 1/4 inch extension bar, a 3/8 to 1/4 adapter, a 3/8 extension bar, a 3/8 to 1/2 inch adapter, a 1/2 inch extension bar and a 1/2 inch ratchet! Never again!
Who can top that nonsense?
Stuart
'90 944 Turbo - Sunroof delete, Factory bridge spoiler, CS wheels, CS steering wheel, 1st MY90 turbo in UK
Promax L2 chips, SciVision MAF, Lindsey DPW, MBC, Forge recirc valve, 3 bar FPR, K&N panel, GAZ Gold, wideband AFR, Sytec Motorsport Fuel Pump.
27 Replies Related Threads
    robwright
    robwright Guest of the Club
    Re: Awkwardness of a simple task challenge..... 2018/08/03 20:02:53 (permalink)
    Ha ha I have been there a couple of times.  I feel your pain brother!
    Rob Wright
    Stamford
    07703671745
    1988 944 Turbo - Guards Red
    Tial 38mm DPW, JMG chips, Siemens 55lb injectors, 9xx race fuel pump, 3 bar FPR, EBC and Bailey DV30 dump valve.
    Frenchy
    Frenchy PCGB Member
    Re: Awkwardness of a simple task challenge..... 2018/08/03 20:50:35 (permalink)
    They do try you at times, getting grief with mine at the moment see cooling fan post.
    Porsche 944 Turbo S (M758) Black 88.
    Porsche 997 Carrera 2 S Artic Silver 54.
    Porsche 944 S2 Guards Red.
    Volvo V50 Sport Grey 56.
    zcacogp
    zcacogp Guest of the Club
    Re: Awkwardness of a simple task challenge..... 2018/08/03 22:15:52 (permalink)
    S2's are easier ....
    On a serious note, 944's generally are meant to be easy for amateur spanner-twirlers to work on at home. Something more modern must be a real pain in the bum (not sure if I am allowed to say that!) by comparison. And yes, I feel your pain too!
    Oli.
    The member also known by John Sims as 'Oil'.
    blade7
    blade7 Guest of the Club
    Re: Awkwardness of a simple task challenge..... 2018/08/04 11:29:34 (permalink)
    My experience after owning a turbo for 10 years, and doing everything myself, is anything related to the engine  is  PITA to work on.  I bought a 944 turbo because it was the best bang for the buck a decade ago. Now I'd buy something like a Golf R/RS3,TT-RS and have more performance without the old car hassle.
    robwright
    Re: Awkwardness of a simple task challenge..... 2018/08/04 21:08:00 (permalink)
    Today I had the pleasure of fitting new rain gutter seals.
    Rob Wright
    Stamford
    07703671745
    Frenchy
    Frenchy PCGB Member
    Re: Awkwardness of a simple task challenge..... 2018/08/04 22:11:37 (permalink)
    Blade, hear you, nowhere near as cool though !
    blade7
    Re: Awkwardness of a simple task challenge..... 2018/08/05 21:55:56 (permalink)
    Frenchy
    This is true, and I'm sentimentally attached to the old girl now
    colin944
    • Status: online
    colin944 PCGB Member
    Re: Awkwardness of a simple task challenge..... 2018/08/06 12:08:14 (permalink)
    I did the rain gutter seals recently. Not a hard job but a touch awkward. the usual 944 job of needing three hands.
    89 944 S2 new floor. sills. and loads of other sheet metal,968cs arbs, rebuilt brakes.all new poly bushes and mounts,968 castor mounts,968 cs steering wheel,cup 1 17 inch 7.5 and 9 inch wheels,and loads of other bits new as well.
    edh
    edh Guest of the Club
    Re: Awkwardness of a simple task challenge..... 2018/08/06 17:12:01 (permalink)
    Most jobs seem quite straightforward (if I can do them they must be..)
    Turbos definitely more awkward than S2's - and every job starts and ends with the intake pipes...
    Changing engine mounts is the one I hated - took me 15 mins on my 996 and all weekend on the 944 turbo!  (mind you, some simple jobs on the Boxster / 996 platform are a pain - for example CV boots & the coolant expansion tank)
    '90 944S2 track car https://www.porscheclubgb.com/forum/tm.aspx?m=685088
    '99 996 C2, '16 M135i, '13 VW Up!
    ex : '00 986S, '90 944 Turbo, '88 924S, '86 924S
    blade7
    Re: Awkwardness of a simple task challenge..... 2018/08/06 19:37:25 (permalink)
    Maybe it's just me, but I found the offside CV joint inner boot a PITA with the gearbox cooler loop, the fuel filter replacement was another job I'd rather not do, and the gear linkage on the top of the gearbox was one I wished I hadn't started.
    Waylander
    Waylander Guest of the Club
    Re: Awkwardness of a simple task challenge..... 2018/08/07 07:45:57 (permalink)
    The most awkward things I have done
    like blade the gearbox linkage was one, but the oil cooler housing with the engine in the hole was a real pain
    1992 Cobalt Blue 968 Coupe
    blade7
    Re: Awkwardness of a simple task challenge..... 2018/08/07 11:30:34 (permalink)
     I watched Ed China remove an M3 gearbox on TV, and wondered then if  German car designers have some perverse sense of humour.
    scam75
    • Status: online
    Re: Awkwardness of a simple task challenge..... 2018/08/07 12:48:32 (permalink)
    Yes removing the OS drive shaft is another bit of finger ballet! I have not tried to do a linkage in situ, will be doing it while my box is out! On the plus side my new cooler solution does away with that stupid loop anyway. After smashing 4 of them I ought to have done this sooner. You live and learn!
    Stuart
    drfc71
    drfc71 Guest of the Club
    Re: Awkwardness of a simple task challenge..... 2018/08/07 18:56:44 (permalink)
    I'm 3 days into trying to fit the door handle drop link onto the ball joint. Wish I'd never started it.
    Waylander
    Re: Awkwardness of a simple task challenge..... 2018/08/07 19:01:24 (permalink)
    Oh yes forgot about the doors and locks, anything with those normally involves skin loss
    PSH
    • Status: online
    PSH Guest of the Club
    Re: Awkwardness of a simple task challenge..... 2018/08/07 19:15:49 (permalink)
    don't bother trying to do the locks without taking the door card, lock shield and associated parts off first... I tried and gave up after numerous attempts.  My son then popped over, stripped the door, attached link to ball in seconds and thus fixed the handle, probably took him about 20 mins, then gave me a roasting for being so stupid.....:)
    Pete
    944 Turbo......was 368BHP/382Torque.... now more...
    scam75
    • Status: online
    Re: Awkwardness of a simple task challenge..... 2018/08/07 19:46:25 (permalink)
    Yeah the ball joint for the drop link is a classic! As Pete says once all stripped off its a bit easier. Top tip. Keep window up and unbolt bottom of window runner from base of door and bend it away slightly. This will give sufficient wiggle room! Removing the door vent also helps iirc.
    Stuart
    IanK
    • Status: online
    IanK Guest of the Club
    Re: Awkwardness of a simple task challenge..... 2018/08/10 16:45:56 (permalink)
    Just try replacing the heat shield that fits just under the exhaust manifold on an S2 - that will seriously test your patience and dexterity in assembling things with one hand that you cant see!
    Ian
    Frenchy
    Frenchy PCGB Member
    Re: Awkwardness of a simple task challenge..... 2018/08/10 21:24:10 (permalink)
    Spent 3 evenings of my life a couple of years ago on hot summer nights with a dremmel and a oil seal pick removing a crush ring from the turbo down pipe, been under mine today with another new fan sensor switch, bled the system fans came on yippee do dah, got the car back down to the garage let the temp rise, fans
    never came on..........**** !
    Looks like I need to bleed it again, not too bad as I don't have to get under it.......again, it is pushing my buttons now !
    That said when it is happy, it's epic, I have a good few hobbies so can walk away and come back to it, chasing Salmon tomorrow as the river levels have risen up here 😀
    Will give it another go on Sunday, once sorted I can get into my E46 330i touring and sort the idle issue !
    Sell up and buy a saucy newish daily, sometimes think about it.............then NAH !
    BORING 💤
    Porsche
    Lockton
    Silverstone Auctions
    Pirelli
    Pirelli
    Oracle Finance
    Archant Dialogue
    HFMC Wealth
    Cornbury House
    Cotswold Business Village
    London Road
    Moreton-in-Marsh
    Gloucestershire  GL56 0JQ
    Call us: 01608 652 911
