Jinxy
Hi guys, had problems with the drivers door window glass for a while now, where the plastic wheel runner would pop off the bottom of the glass channel, i thought i had cured this problem when i bought some expensive replacement wheels from the U.S.A, i fitted these & all was well for a while until last week when i noticed the glass had dropped again, i soon popped the wheel back on & greased the channel & the wheel, only for it to pop off again a few days later, it seems to be the same wheel each time, so i decided a different approach was needed, so i swapped the lifting scissors for another set i had, swapped the new wheels to this scissor & fitted the offending wheel to face the inside of the car, my theory being that if it was slightly worn it would be held in place by the slight pressure on that wheel, all was ok for a day, but tonight its popped off again !!, ive now come to the conclusion that the window felt swells slightly when wet, this combined with the sub zero temperature means the glass tends to be quite tight in the channels & i guess something has to give, does anyone else have this problem ? if so does anyone have a cure ? apart from the obvious " dont lower the window in winter" chestnut LOL !! cheers, Tony
