nicksonmsport
trying to accurately identify some brake calipers i have.
i believe both of them are either 928s4 or 968 m030 calipers
they both look identical apart from the piston size, they both accept the same pads
one set has piston sizes approx 32mm/40mm on the outside diameter
the other calipers are 39/45mm od (size of piston housing)
i can see part numbers on the inside of these calipers which are 20.4565.00 and 20.4564.00, the different part numbers dictate each side of the caliper (2 part caliper)
they both have exactly the same mounting points (radial) and the same inlet port, and 2 bleed nipples at one end.
can any1 identify each caliper for me
many thanks
nick
many thanks
nick
