Wheels question
Jez.
Are you trying to fit it to a 968/944 car.??
Is the wheel a 9" / et70.?? OR 8" / et70.??
It all makes a difference.......
Im presuming its a 9" wheel...?? Then yes it will fit to the rear.. BUT you might need some spacers, as the original wheel is a et55, so i make that a 15mm spacer needed....
Hi Dave, it would be a 968.
The wheels are 17" Cup 2's originally from a 993.
The fronts are 7" with an ET of 55.
The rears are 9" with an ET of 70.
So I guess that would be 15mm spacers then as per your post???
