Wheel Offset
944 man
951/952? What is the difference? 952 is the part number prefix for unique Turbo RHD parts. All 944 Turbos are 951s whether they 23.3mm offset, 52.3mm offset or later 250PS models. Its hard to give you an accurate answer when the vendor hasnt given you a proper answer to your question. Presuming that the fronts are ET40 then they will fit, but 9" ET16 rears would only fit inside a widebody aircooled 911s arch! Unfortunately spacers are only able to help where the wheels are too far in. These are already way too far out.
I've been offered some 17" wheels but i don't think the offset is going to work. I've a '90 944 Turbo and when questioned i've received the following reply:
Rear wheels marked ht sn rota svp2/07 e16 9j 17
Fronts ht sn rota svp1/07 7.5j -17 with a tiny 40 stamped next to it
Thoughts? I'm thinking they may be correct for a 951 but not 952? If my hunch is correct, could they fit with spacers?
PCD is correct (5 x 130)
