What anti freeze do you use?
Should I be topping up my Sport with Porsche anti-freeze? Do they even make such a thing?
What do other people use?
Chris
OPC at Nottingham used Antifreeze Prot? Part No. 000.043.203.78 in my 968.
3 units (most likely litres) @ £5.26 +VAT
I had the belts, rollers, etc and exchange water pump fitted at the same time.
Mike
Mike
Would you mind telling us what you thought of the service at Nottingham? Also, I would like to know what sort of money they ended up charging you as I am close to needing a similar job done. (see the other thread on belts and chains)
paul
Paul
Obviously the work is carried out to a high standard, although the service seemed to have suffered a bit (although they had just moved to new premises and the waiting time could be spent lusting over a magnificent looking red GT3) from the previous year.
My car has a full OPC service history and they had pointed out that new full strength antifreeze would seep past the water pump that was displaying signs of leakage.
So I bit the bullet and had the work done with them, probably one of the most important jobs on a 968. The cost was very nearly £1500 including routine servicing.
One slightly worrying thing was despite having had 6 weeks notice and the car for two days the service guy told me (prior to collection) that I was lucky that they had had the parts in stock![&:]
I think had my car not had an OPC service history I would have saved a packet and gone to my local specialist.
Mike
Mike
thank you for your reply, really helpful to hear your approach to this OPC service issue.
paul
ORIGINAL: legaleagleboy
Mike
paul
I had 24k service at the OPC staples corner. Got it back with enought water in the rear footwell to keep fish, condensation in my front fog/spot lights and reart lights, grase on my bumper and no top on break fluid, clutch fluid and coolant. The water came through from the jet wash they used to clean it with so i ask them to dry it out! And then told them to top up the fluids. Making two trips to Staples Corner. It made me wounder did they do everything else there surpose to do on the check list!!! Cost for a 24k service £460!
