water leak on my 944
- Thread starter steve944
pauljmcnulty
First thing to check is remove the sunroof and pour water carefully down the four drain holes. If it doesn't come out under the car, you know it's blocked. Be careful clearing them, as the drain tube is pushed on to the sockets under the sunroof and a pig to re-attach; flexible nylon wire, like strimmer cable, is best.
Another obvious one is the drains in the front bulkhead. The area under the bottom of the windscreen fills with leaves and muck, and there are drains here as well.
There are plenty of other possibilities, but these are the most likely.
A few things that cause leaks in the front are
battery tray( b4 85.5 so your ok there )
Windscreen need rebonding.
Front sunroof drain tubes, these run down under the trim in the corner off the windscreen, and out in 2 the front buck head.
Heater area under the windscreen wipers.
Door sills
Do some tests when it's dry, isolate areas, like just sunroof drain tubes. Pour water in to them and see if the floor gets wet.
Try the below the windscreen
And then the windscreen.
Today when I was in the car I had my foot on the brake pedal and could feel a slow drip so at least I have an area to start with as well as all the suggestions on here.
Stevie.
j4mou
A car cover is the answer
david924s
