My back was feeling better over the weekend so I had a better look for the water leak I was getting into my 944.
The water was gathering in the rear passenger footwell. Stripped seats out and pulled the carpet back, and some of the rear quarter trim. Got the other half to spray the hose around the car, hatch, rear windows, underneath, windwscreen, scuttle, etc - nothing, other than a fair amount of water coming in on drivers side of rear hatch.
After having a good look it seems to be getting under the headlining. The hatch seal on this corner does seem a little un-squashed, i.e. when the hatch is down it doesn't really trap the seal. However it looks like the problem is that the seal has lifted a little on the roof side which is allowing it to run in behind and get under the headlining. It could be that if the seal was deformed by the hatch it would compress it enough, but I couldn't get it under there without trapping my fingers!!
Only other thing I noticed is that where the headlining has shrunk back, and it is usually doubled over the lip where the hatch seal fits over, on the corner it has shrunk enough that it is not doubled over. I wonder if this is part of the problem, where there is not a continuous thickness of vinyl underneath the seal, it could be leaving a void.
When refitting a hatch seal has anyone had problems with the vinyl, or does it sound like the seal has just swollen/grown a bit? I have put a load of silicone grease around the area for the moment until I get a new seal - but I'm thinking that if part of the problem is the way the headlining is uneven underneath the seal, then I need to factor in replacing the headlining at the same time. Luckilly it only seems to come in when hosing that area, if it's only a light trickle of water (i.e. rain) then it doesn't seem to come in (at any great rate anyway).
Shame, as it has ruined the rear quarter trim panel on that side as well!
