Hi
Filled the washer bottle this morning and then lost all of the water after starting the car 10 minutes later.
the washer water gushed out from under the passengers side PU so obviously not the main tank/bottle that’s the other side of the wheel, i’m assuming its the pop up headlight washer or pipe.
Im away until Sunday night but planning a trip abroad next weekend So need to sort it during the week.
Any thoughts as to if this is likely to be repairable other than clamping the pipe short term before the leak? I’m assuming whatever it is ill need to remove the PU or inner wheel arch to get in an investigate.
regards
Karl
regards
Karl
