Hi
Having had a starter motor replaced some months back (as per separate recent thread) I have recently noticed that warm starts are getting more difficult - i dont think this is related to the starter motor change as the car has started well since the starter motor was replaced, it must be 50 starts since that point and until I had noticed the issue in recent weeks.
Starting from cold I think it feels ok, circa 3 seconds of cranking, i am debating in my mind if this very slightly slower to fire? Once the car has been run and heated through, if I restart after a short stop, maybe a refuel, the car starts but it takes just a little longer to fire than I recall of old. If I leave it for say 30 minutes then the restart would be difficult, strong turn over but not firing. If I push the accelerator this seems to help it fire and then it runs without issue. No issues that I can feel when running.
The car has always been superb on warm restarts, literally a very quick crank and it fires, no need to touch the accelerator.
Pretty sure this is going to be a return to garage as I have limited tools etc, but I am interested in any guide points before I go to the garage, or maybe there is something simple you think I should try before I go?
(Did cross my mind if this could be DME relay related for example? Beyond that I did read a few threads on fuel vaporisation and engine temp sensor issues but not things I could really check as far as I could see)
Thanks as always
Darren
Thanks as always
Darren
