My 944S has quite a distinct vibration when pulling away, it could be exhaust resonance/engine labouring a little, but it feels more like a moderate vibration to me.
It seems to be around 1500rpm and is gone above 2000rpm. There is no obvious vibration at idle, and although it does vibrate a bit more when you rev (while in neutral) between 1500-2000rpm, it only really vibrates as you load the engine up - i.e. pulling away.
Is this normal, or likely to be something like the engine mounts?
