Certainly a long list of work, not sure on some of it though - the square arches, the wheels, the raised gear lever etc. A lot of personalisation to only run it very briefly once finished.
Work list from the ad:-
Engine
2.5L
Lindsey Phase III Racing head,
fully ported, Flowed
cc ed, large SS valves
Lindsey performance springs
titanium and moly caps et...
Cometic head gasket
Web cam
Speed Force Racing custom made equal length intake manifold
BBK 75mm throttle body
Lindsey adj cam gear
Lindsey Balance shaft delete
APR head studs
Pauter forged rods
Lindsey 1" custom crankcase ventilation kit
Lindsey oil pan baffle kit to prevent cavitation
Lindsey under drive pulleys
Load Boss light weight alternator
Braile gel battery
Broadfoot Racing alternator bracket
Wizard Cooling custom radiator
Earl's oil cooler
Canton racing oil filter relocation kit
Canton 3qt accumulator
Custom 1000ci high efficiency air to air intercooler
Custom 3" intake hard pipes
Custom Borg Warner hybrid turbo charger
Lindsey 962 style dual waste gate
Turboronics Godzilla Blow off valve
TurboXS Dual stage Boost Controller
Ferrenza lightweight aluminum flywheel
Kennedy Racing light weight pressure plate
Clutch Net 6 puck E-Z lock spring hub clutch disc
Bosch 1200cc high impedance balanced injectors
Custom dual feed fuel injector fuel rail
Aeromotive A1000 fuel pump
Aeromotive A1000 fuel pressure regulator
Perfect Power stand alone ECU
J&S Individual Cyl Knock Control
Custom Distributor less ignition
Magnacore 10.5 wires
MSD coil pack
Kokeln solid motor mounts
Custom 3" SS to 4" aluminum exhaust
and much more
Transmission
5 speed gear box
LSD diff
Trans oil cooler
cooler fan
trans overflow tank
trans temp sensor
Tilton differential pump
Kokeln solid trans mount
Kokeln short shifter lever
Hamburg- Technic short shift kit
Custom elevated shifting assembly
Suspension
Adjustable tie rod bump steer kit
Billet "Charlie Arms" lower control arms
Billet Bearing front control arm bushings
Weitmeister front and rear sway bars
Adjustable drop links
1/2" recessed Ground Control camber plates
Ground Control front strut bar
Custom Ground Control coil over dual Adj Koni front shocks
Eibach springs
Welded and lightened rear spring plates
Torsion Bar delete
Spherical bearing and aluminum trailing arm bushings and blocks
Custom Ground Control rear Coil over single Adj Koni shocks
Rebuilt rack and pinion
Rebuilt power steering pump
Brakes
993 Twin Turbo Brembo Big Blacks front calipers
964 3.6l crossed drilled direction vein front rotors
968 front Brembo calipers installed in the rear
SS flexible brake lines
Interior
Custom seats
Removable steering wheel
Custom pedals
Helmet blower system
Ultra Shield Belts
Wink mirror
light weight ext mirrors
Auto Meter Shift lights and Warning lights
AEM Boost and Air Fuel ratio gauges
Stack Tach
Sparco Electronic fire suppression system
MoMo steering wheel
Custom Fiberglass dash
Custom center console
Custom 13/4" roll cage by BRE motorsports
Much more....
Body
Broadfoot racing composite front end
Custom CCP Fabrication composite fairings
Custom CCP Fabrication Composite splitter
CCP Fabrication composite hood
Aero hood locks
Custom CCP Fabrication composite header panel
GT Racing Composite front fenders
GT racing Rear panel flares
CCP Fabrication Rear composite bumper
CCP Fabrication Rear composite wing
Custom rear wing uprights tied into the frame
Lexan front, rear and side windows
Rennline tow hooks
Light weight rear view mirrors
ECU software included, receipts and extensive Spec book with all electrical diagrams et.. included.
Car does have a clean title and car weight is approx. 2550 lbs wet with a 1/2 tank of fuel. I believe the car could get into the 2400's with a few minor changes.
example- removal of the 2nd seat
lighter Battery et.......
