Jinxy
Hi Guys I have a 1989 2.7 944, this morning at 2.30am I went to get in my car for work when I noticed a strong smell of fuel, so using my phone as a torch I looked under the rear of the car & the ground was clear no evidence of a fuel leak, I then looked under the front of the car & noticed a wet patch just behind the drivers side front wheel almost under the drivers door, I followed this & it looks to be coming from the group of pipes that run behind the front arch liner between the inner arch & front strut & the fuel is running down the pipes to the lowest point, visibility is quite limited under there without removing the liner itself, but if I look up between the liner & inner wing it looks to be pretty wet up there, just wondered if this is a common area for a leak & if it is what part is likely to be the culprit ? im fearing a fractured metal fuel pipe, which means it will probably be a pig to do & cost a small fortune to repair, im good with tools, but its the time & parts cost that's worrying me. Leak isn't too bad at the moment, its not gushing out, maybe a drop onto the floor, every 2 minutes or so. any help appreciated, cheers, Jinxy
