Under Tray
- Thread starter Bungditin
mcgc0
mcgc0
Bungditin said:My service man tells me that running without can affect engine cooling, so I will replace if I can.
TBH, I think you'll find the jury is out on that one from other long-term 964 owners. I sprint mine often on 5-hour day long trips and usually @ 5k revs. Highest oil temp reached @ 110oC (or just above 09:00 position on gauge). Quality oil a factor too.
Typically a service centre wouldn't deviate from the Porsche standard and fair enough. However, the undertrays were primarily for undercar aerodynamic efficiency in Porsche needing to achieve acceptable overall fuel efficiency values (leading to regulatory US emmission reqs). Undertray slots were added to improve what would have otherwise been lack of heat removal. No undertray - less high speed motorway under car aero efficiency (if ever high speed of course).
As always though, it's down to owner preferences, as it should be.
Stephenjk
if your car's cooling is fine you could easily cause yourself a fair amount of time and money and end up with more problems than you started with by putting the tray back on. That is my experience on these types of jobs. Even doing something relatively small can turn into a surprising amount of work once fixings rust and stuff breaks.
If you want one for your vehicle, get one. Porsche didn't fit them because they felt like it they were fitted for a reason even if it was just to tidy up the underside of the vehicle.Bungditin said:All good information guys, thanks.
Ray
On the issue of heat it is more important to check the oil cooler fans are working correctly. I would guess the low speed fan is not working on more than 75% of cars. When its working correctly the oil temp will be held around the 8 o'clock marker in standing taffic. If your temp gets to the 9 or above then chances are the low speed fan isn't working. High speed operation is about the 10 o'clock mark.
mcgc0
ras62 said:On the issue of heat it is more important to check the oil cooler fans are working correctly. I would guess the low speed fan is not working on more than 75% of cars. When its working correctly the oil temp will be held around the 8 o'clock marker in standing taffic. If your temp gets to the 9 or above then chances are the low speed fan isn't working. High speed operation is about the 10 o'clock mark.
Agreed. A quality oil of right viscosity also helps - even essential imho. When I changed my oil type I never had high temps above the 9 o'clock mark any longer. And that's without the cooler fan working for the last two years!
ras62 said:They were installed to meet noise regulations but they simply trap heat hence the reason many are removed.
On what do you base this?
The majority of owners are using reputable specialists for servicing, and if this was an issue, they would be advised of it.
mcgc0
colin129 said:The majority of owners are using reputable specialists for servicing, and if this was an issue, they would be advised of it.
My opinion on this would be that specialists wouldn't advise either way tbh, and I wouldn't expect them to. Deviating from what Porsche built or intended isn't really in their interest to advise the opposite (on the record of course). I think for most owners we rely on the experience, skill and knowledge of others who might know or have practised and have credible feedback from. Rennlist is full of undertray technical debate. Seems ensuring that heatshields around the bottom half of the engine remain in place, and not removed either, is the key issue. Personal preferences as always dictate I guess.
colin129 said:ras62 said:They were installed to meet noise regulations but they simply trap heat hence the reason many are removed.
Unless checking in particular for the low fan speed operation it's not readily apparent if it works or not tbh. It was my Indy who said most don't work, they didn't see this as a big deal but would be more concerned if the high speed fan didn't operate for obvious reasons. I would doubt if many specialist could accurately tell you the operating temps for the fans tbh.
Bad balast resistor is often the cause or as in my case the CCU driver was defective. I've just rebuilt my engine so would rather keep the temps around the 8 o'clock mark in traffic rather than see the temp climb up past 9 o'clock before the high speed fan kicks in. I have installed a low speed manual override to do just that.
