Tyre pressures
In my owners manual for a '89 coupe it says Front = 2 bar (29 psi), Rear = 2.5 bar (36 psi)
Hi David, had already replied to your previous post....
It will vary slightly depending on tyre sizes etc but on my SC (16 inch tyres) I run 1.9 bars front and 2.2 rear (cold pressure) if it helps (i know I am running rears slightly lower than prescribed but settled on this after many miles of experimenting and my preferred choice).
You should have a sticker in the engine bay I believe and on 3.2 it says 2bars (29psi) and rear 2.5 bars (36psi) as per reply above
I tend to run my rears at a slightly lower pressure of 32-34 PSI, feels more comfortable and grippier, to me.
For normal road driving not sure it is that critical, but nice to get the pressures close.
You can set them at 15 deg C and on a hot day, say 25 deg the pressures will be quite a few psi up.
I just check mine before a reasonable length journey.
