Tyre Pressures
- Thread starter Guest
Diver944
Other 944 owners with 17" ' s have recommended 32-34 psi front and 34-36 rear which I have followed for about 10,000 miles now with even tread wear all round
So many different factors come into play. Ambient temperature. Track temp. Your driving style etc. New tyres should not be thrashed because they will need to cure. Thrash them and trash them so ideally do not fit just before going out on track. Ideally change just after track day ends and run new tyres in. For road use go by handbok to start with and raise/lower by a few psi to find best for you. Handbook is normally suitable for most road applications.[
Robbiemeister
When I checked Dunlop' s (I think) website they quoted the same pressure for all the 968' s as the later 944' s. 36psi all round if I remember correctly.
Diver944
After much discussion with other owners on www.titanic.co.uk/944 I reduced my rears to 36 psi and the car felt much better and 40,000 miles later I have not had excess wear in the middle of the rear. When I bought my '89 Turbo last year, sure enough it stated 36 all round????
I don't know the reason why the change but 944 owners 'legend' tends to agree that it was raised to counteract possible high speed (140mph +) blowouts on German Autobahns. Normally I would always, always say follow the manufactureres guideline but in this case I just cannot agree. 44 psi is way too high (unless you are planning any Autobahn trips [
the rear always felt 'loose' and noisy.
Well don't rev it to 5K and dump the clutch then
Many manufacturers recommend higher tyre pressures for high speeds or heavy loading, perhaps Porsche opted for 44lbs as a catch all situation. High tyre wear in the middle of the tyre would demonstrate over inflation so 36lbs does seem to be the best route.
berg944
the cheapest handling mod ever......air
My tubo had 30 psi all round when I bought it, so I kept them at this for a while.
The car wandered when it hit grids and tended to follow white lines, I thought it was the wide tyres or the front geometry.
The steering is know lighter and better. It drives where you point it (except in the wet when the rear end wants to overtake)
Mike
chris_boyle33
when i first got it i had them at about 40ish all round. it was a bit more interesting when wet, but pretty much okay.
I had a slow puncture on my passenger side rear, which i've now replaced. i damaged the tyre by driving it when it was down to 9psi. i didn't really notice much difference whilst driving it like this (until i got out the car and looked). You may by now be realising that i'm not the most fussy person on tyre pressures - so perhaps someone else could answer this better ! [
p.s. - does anyone know whose car this is which i've pinched as my jpeg? Its not mine, but its red and looks like mine. I really should have asked the guy if he minded before i pinched it - it was about a year ago now tho. Sorry!
Diver944
Confused yet [8D]
Diver944
We all know that too much air in a tyre will cause wear in the middle, and not enough air will cause wear on the shoulders.
One way to determine the optimum pressure for tyres ensuring that the full width of tread is making contact under your driving conditions is to draw a line of chalk, or Tippex, or masking tape across the width of the tyre. Then go out for a drive, stopping regularly and checking where the marks have worn off [8|] Adjust so that you get uniform wear but then keep an eye out over the next few 1000 miles.
<Anorak off>
Me, I just set mine to the factory 36 (for my car) then lowered a bit to 34 when I spotted slight wear in the middle
pae
the idea about a tippex line across the tyre sounds neat - might give that a go and see what I learn. Anorak on, reporting for duty.
cheers ........ Phil
Diver944
I run my 17" wheels at 34 front 35 rear, this gives even wear across the tread. 44psi at the rear, wears out the middle in a few thousand miles and makes the car horribly loose at the rear
