Dan944t
Hi guys ,
im a little suspect of my electric auxiliary water oumo for the turbo water circulation , as I’ve not heard it for a while and used to and it’s also got a bit of water coming out from what seems to be the main blade part as I’ve revealed it already and that part looks good. Think it may have given up the gost?
My wuestion is cab this be tested off the car for operation if the motor the motor by the two wires?
also if I wanted to buy new, is there another alternative I can use just by changing the wire connector from double flat spade type to our prong type?
Ive found a few, one being a bosche item that looks the same and it’s under £60 I’ll try out link up
https://imgur.com/a/2akhxyR
