I changed out my stock pads for Ferodo DS3.12 pads after the stock pads left deposits on my steel discs after track use. This resulted in vibration when braking at around 70mph.
I sanded the deposits from the discs when changing to the DS3.12's & applied Ceratec at the hardwear contact points. Bedded in etc & this completely resolved the vibration issue.
However the squeal is annoying with these pads, albeit the performance on track is good.
I'm probably searching for the Holy Grail of brake pads but I'd like a pad that performs well on track but doesn't squeal like a pig.
I'm considering putting my stock pads back in but will likely end up with pad deposits on the discs again.
Any recommendations for combined use pads that don't sound awful at low speed stops?
I'm not sure such a compound exists, even my stock pads squealed in warm weather for the first 2000miles then weren't too bad.
