TQ: 924 fuel distributor
PaulHere
Technical Question - Copied from the Classic & Heritage area of the forum
New to this but can anyone help.I have a 1981 924 that seems to gulp fuel I can even smell it from the exhaust! I have stripped down the fuel dist. and the piston inside fell out in my hand. Is it possible to replace the rubber seal on the pison or does the whole unit need replacing?
I have looked for the answer on site but still getting used to the site and the search tool?
Any help would be appreciated.
Neil
Two things. If you haven't already done it then stop right where you are and do not attempt to dismantle, i.e. separate, the two halves of the metering head.
Before condemning the head check the connections to the warm up regulator, if there is no currnet flow then the mixture will be permanently enriched. Check the earth too.
The mixture can be adjusted. Remove the red plug from the body and use a 3mm allen key to turn the adjuster anticlockwise to make the mixture leaner.
I am working from memory here, and as I recall, the only O ring is between the head and the plate housing, and provides an air-tight seal between the body and the casting. I don't recall seeing one in the bore for the piston/plunger.
The plunger and bore are honed to extremely tight tolerances and it has always been my understanding that the components seal due to their good fit. They do wear and let fuel past, and if this is the case there will be fuel residue in the bottom of the air-filter plenum chamber below the metering head. The system is so sensitve to friction that I think any O ring used to seal, would, over time, swell, and inhibit the movement of the plunger, making the metering of the fuel hoplessly inaccurate.
Am I right in thinking that you beleive that there should be an O ring or seal in the groove in the piston, or plunger? If so I am afraid that is not the case.
The position of the groove, relative to the outlet slots in the bore within which the plunger slides, are what controls the volume of fuel flow, and, as I understand it, the position of the plunger, relative to the slots, is proportional to, and controlled by, the angle of deflection of the plate. Simply stated, and this is a simplified version of the operation, when the regulator is cold, and is in it's bypassing state, fuel pressure, which is present both above and below the diaphragms and plunger is reduced in the area above the plunger, because the bypass orifice is larger than the inlet to the top of the metering chamber, so cannot stabilise to system pressure. This unbalances the system slightly and allows the plunger, which damps the movement of the plate, to move further up the bore thereby exposing more of the metering slots to the void created by the groove in the plunger, allowing more fuel to flow as the plate finds a new stable position in the airflow for the same flow of air mass balanced against the increase in fuel flow, which offsets the imbalance caused by the bypassing at the warm up regulator. SIMPLY STATED.
Hope this helps.
Thanks for your 'Simply Stated' version I think the complicated one would have needed more than the half bottle of wine it took to translate the simple version!!
I think that i had better take a good look at it over the weekend.
Thanks for your quick response it gives me something to go at before I start replacing parts.
Neil
Alcohol free version.
The air is sucked into the engine past a plate, which "flies" in the airflow.
Fuel pressure is used to control the angle of the plate, balancing it against the airflow.
The angle of the plate controls the fuel flow.
The warm up regulator lowers the fuel pressure acting on the plate, when the engine is cold
The plate moves through a greater angle.
More fuel goes into the engine.
Soberly
the nutter.
924nutter knows his way round 924's & usually gives a good answer, well worth a listen, or extended read with or without alcohol in hand. [;)]
Coming back to the original question, overfuelling can also be caused by insufficient control pressure on the metering head. Control pressure is determined by the "warm up" regulator. Even more critical to get this right on a turbo car as the WUR also has a boost enrichment device.
