Touch of preventative maintenance: 987.2 2009
911hillclimber
Cool dry day here, so set to with a can of Dinitrol cavity spray and drowned my nice new and very expensive cross-over front pipes.
Having invested in nearly £1200 to have these done, the most expensive job on my Boxster so far, so to keep the corrosion at bay (a bit) I've liberally coated the rubber hoses joints/alum cross over and plastic pipes in Dinitrol.
Bit runny, bit sticky, but searching at first then a drying to a wax coating.
Should do the trick.
Checked the front brake pads/discs while exposed.
About 2mm left on the pads which a bit of a surprise as I am a master of gentle braking (or so I thought).
Wanted to check them carefully as they sound a bit rough, but the car certainly stops when needed.
Those 19" rims are sure heavy...
The old Bridgestones are now about 2/3's down and I hope I can arrive at the point where all 4 need changing and I can go to another brand to kill the road noise a bit.
Any suggestions on quiet tyres please? Not interested in track/ high speed grip etc, just comfortable touring driving with excellent rain dispersal.
New tyres are always quieter than old ones! Black Circles give you the dB, wet braking and fuel economy ratings for all tyres so that's a good place to start depending on your tyre size and N rating (or not).
