thermostat???????
- Thread starter craigjudd
George Elliott
If you go to clarks garage on the web, and under site search type in "thermostat" it will talk you to it.
hope this helps
good luck
George
944t
Outrun944
Just wondering... does the thermostat sit at the end of the hose going into the engine block that end? I'm not sure from what they describe on the site ..
From this pic -
http://upload.wikimedia.org/wikipedia/commons/d/dc/1986_Porsche_944_engine.jpg
Is it the top hose going into the top of the engine block in the middle of the pic near what I think is the bleed screw?
Or the bottom hose directly down from it?
George Elliott
George
Undo the hose clip (may want to drain coolant first) then the 'stat is held in by a circlip and should come out easily - reassembly is the reverse!
Fiddly little job though, angled circlip pliers recommended.
