Ok well its been a while since I posted asking for advice but the time has come. I have around £1500-1600 and I'm extensively searching for my ideal 944. I've seen a few examples in my price range. One is a ruby red that has had complete front end strip down including tensioners and pulleys, water pump, manifold gasket, major belts (including timing), bearings, brakes (including shoes, pads & pipes), fuel lines, radiator, steering shaft; bearings and rubbers, drive shaft flange, balanced shaft gear, stabilizer bush, windscreen and wipers, boot catches and rubber, new leather steering wheel and gear gaiter, radio aerial, all done in the past few months. Sills look solid from pictures, one small rust patch forming on the front of the off side rear panel, no bigger than a hand probably. Seat is torn and dash has a crack but mechanically and electrically everything else is fine. I don't mind a rolling project and I'm really just asking whether this would be a good option?
Thanks!
Thanks!
