924Srr27l
2021 Well maybe............! Dependant on the Virus Corona Beer lurgy! (Which I've had and recovered from now)
But the restrictions are looking to cancel many events so with the first round on April 5th this night not happen
(But the car wouldn't be ready for this anyway!)
The 2nd round is at Croft May 30th which has a better chance of staying.. and the car being ready
The 924 is no longer and a 944 is now the evolution 2 race car that will be extensively modified to suit the race regs
which allow wheel arch extensions to be fitted with a maximum total additional width of 200mm - 4"
(The Picture belows shows a GT-R which has the same arch kit being fitted)
2 & 3 hour Endurance racing is very hard on any car especially when compared to the usual 20 minute spring racing, hence
the car needs to be build to be much stronger (Chassis & Suspension) and more reliable (Better heat control Engine & Brakes)
www.youtube.com/watch?v=7thEwzObrcI
The chassis is a 1987 944 (Aluminum front wishbones & Rear Trailing arms + Aluminum cross member)
The Engine is a 944 (1990 3.0 S2 block / 1990 951 Crank / 1987 2.5 cylinder head) as is the 016 Gearbox (With LSD)
The Front Stub axles / hubs / Discs and rear hubs / discs& all the brake calipers will all be (Early )1985 944 Turbo (Brembo) items
with the expensive but astounding (Price & Performance) Pagid RS Brake pads (£500 ! for all 4 corners)
- More aero development on a new front splitter (Wider & adjustable lip from 2-4") to match the wider front wings & arches
- Side Exit exhaust (With 1 straight through Silencer)
- Rear Diffuser tunnels (With the silencer gone)
- Wider wheels from 8" to 9"
- Lighter wheels from 8x16 Porsche cups to 9x16" BBS RS splitrims (1.5kg lighter each)
- Wider tyres 215mm to 245mm
- Softer compound from R888 Toyo (Treadwear 100) to Pirelli Trofeo R (60) @ £1000 a set!!
- Bespoke 935 design Front wishbone & Caster arm / mount
- Roll correction Front stub axle & Steering tie rod extensions
- Lightweight rear torsion tube (Solid mounted to chassis in 4 places) Torsion bars removed
- 935 Blade type Uniball rear spring plates
- Turbofan Wheel covers (Brake cooling) + air Ducting from front lower spoiler
- Radiator position angled to exit up through the front of the Bonnet
- 16 Row Oil Cooled fitted & Oil Temp cockpit gauge
- Strengthened X member Steel brace
An much more..........
R
R
