Hello to all, probably a subject that has been discussed in the past but rapidly getting to my wits end..... My 83 SC alternator failed around a week ago. Had the original unit repaired -great.
Re-installed it, but can I get the belt tight? I can get the car running ok, alternator warning light off, but the belt is still loose and heats up pretty quickly (as does the pulley) and unpleasant smell comes from the belt. Prior to being taken out there were three shims either side, i have tried every combination known to man i think in terms of 4 on this side two on the other etc etc to get it to tighten up. The difference however appears negligible wherever the shims are, the only difference is the angle between the pulley and the crank pulley. I have checked the alternator is sitting in the fan housing correctly, tried to ensure the whole fan and alternator assembly are correctly located before doing the shims bit, and i am fairly sure it is all back as it should be but!!!!!
I am not sure how the system actually works either really, in that you are able to put three shims on the alternator side, hook the pulley into the belt whilst its attached to the crank, without much effort then put the pulley on to the end of the alternator, then stick the next three shims inside and put the cone washer on, nut and then crack it up pretty tight and its still loose! At what point do you get some tension. Or am i doing something wrong????
Any help - advice greatly appreciated, unless anyone wants to buy a very cheap SC cab after i have set fire to t!
Best wishes
Jonathan
Best wishes
Jonathan
