chrisg
Morning All !
For the more technically minded or experienced, what exactly does the temperature sender that sits in the water feed (banjo joint) to the turbo do ? This sits on the LHS of the turbo - you can just see it under the inlet manifold very close to the throttle body and it has a single yellow wire going into it.
I've looked on the Electrical diagram and it just feeds into the DME.
The reason I ask is mine looks suspiciously knackered = sender is wobbly and not secure but no water leak.
I've ordered a new one from OPC, but I'm reluctant to start fitting it in advance of the Ring trip in July - looks very difficult access and really best to do once Inlet manifold is removed.
So, what exactly does it do and what are the potential consequences of it not functioning properly ?
thanks in advance,
Chris
thanks in advance,
Chris
