I have a 1983 924 and have had problems with starting it from cold (engine turns over but won't start), replaced the fuel pump relay and it was OK for a couple of weeks and then wouldn't start again, [
]although it would run if we by-passed the relay .
I replaced the fuel pump (and the relay) last week but it still isn't starting properly or running very well particularly when there is under half a talk of fuel. In the last couple of days it has developed a slight buzzing from the near side rear, understand that there is a second lift pump in the tank.
Question is ... does it sound like the lift pump is the problem (is there a test?) or can anyone come up with an alternative ?? secondly, how do I go about fitting a new lift pump, I can't see that it's mentioned in the haynes manual ??
