tap tap tap
- Thread starter Ryan944
mr brightside
Isn't it caused by some check valve thingy in the head failing, so as to let all the oil drain out overnight?ORIGINAL: zcacogp Noisy tappets when cold is part of 944 ownership. As long as they quieten down within a couple of seconds of starting then it is nothing to worry about. Oli.
mr brightside
I'll take your word for it, i'm actually glad the case may be that mine hasn't failed as i thought. It's only rappy on one when it's cold, it's embarrasing but i can put up with it if everyone elses is doing the same. I'm thinking of getting the head rebuilt this winter to try and stop it smoking, are the tappets cheap enough to be worth changing? I'm thinking of fitting one of those fast road cams from america (JW or something?) and a new cam is going to require a regrind and reshimming of the old tappets at the very least i suspect.ORIGINAL: zcacogp MrB, I have heard tell of this valve, but I think it rarely fails. Isn't it the case that they are all noisy on start-up, but those with the failed valve are very noisy? Oli.
mr brightside
Cheers. Google's a bit light on technical images but there's just enough for me to get an idea of what one looks like, i had no idea they were so complex. I think i'd still have the cam end tappet faces polished up leaving a few witness marks just to make sure they were completely flat if i were fitting a new cam.ORIGINAL: zcacogp MB, The tappets don't need grinding or shimming. They work with little hydraulic pistons, and 'pump themselves up' to the right size. Hence zero-maintenance, but if they drain all their oil overnight then they are noisy while 'pumping themselves up'. Google them for a better explanation. Downside is that if they get noisy then you either live with them (taking steps to make them as quiet as possible), or replace them. You can't adjust them by re-shimming them. And replacing them ... let's say you probably need to be sitting down when you learn the price of them. Which is why everyone lives with them being a bit noisy. I could be wrong about the valve preventing oil drain ... it sounds familiar (from what I have read on here), but I could be very, very wrong. Always a fact worth bearing in mind! [&:] Oli.
Thanks for your offer Alasdair. I've got into the habit of letting other people fiddle with my Porsche, i'm more of a push rods and carb person, but i'm sure i could stretch to removing the rocker top.ORIGINAL: sulzeruk The internal valves in the tappets will be shagged letting the oil flow out of them. Worth nipping the cambox off next time the belts need done and checking them all. If you can compress the pad with your fingers, they are U/S. I have a big box of good S/H ones if you want any, £5 a go. New ones are rather pricey! Alasdair
Interesting - thanks. Do you need to take the cams out to get the tappets out? Oli.ORIGINAL: sulzeruk Hi Oli, complete pish puts it mildly. It is a mechanical part, just like a mini shock absorber internally to take up the clearance between valve stem and cam base circle or lobe so really not many wear parts. The only problem you get is the small needle valve to stop the oil flowing back under pressure. When these become damaged or worn, that's why you get noisy tappets. We changed a cpouple recently in Stuarts (scam75) turbo as 2 of his were soft. Car now a lot quieter.
scam75
Well-known member
david924s
