Hi. I would like to hard wire Car Play to my 2001 986 but not sure which fuse to piggyback from as I don’t want to drain the battery so only want power to the Car Play unit when the vehicle is switched on. Any suggestions would be appreciated. Cheers
Switched v constant fuse
- Thread starter bradley.clinton-parker
Hi. The owners handbook details the fuses in both of the footwell fuseboxes. IIRC, the left-hand (passenger) fuse box has more switched options and more space. Exactly which fuses are fitted will depend on the equipment spec of your car, but you'll also see there are some 'spare' fuseways that you could use. Always best to double check with a multi-meter before diving in. I'd also avoid piggybacking onto a high-value fuse (eg 2OA+) or anything that feeds multiple circuits.
Much appreciated guys. Many thanks
