Sunroof failure
- Thread starter drfc71
Copperman05
Edd
They were £3 each about 4 years ago. And then £6 each about 2 years ago. Could have bought a stockpile if they are now £12 each and called it an investment ...ORIGINAL: T3rra
There about £ 8/12 each
Adjust the clutch in the rear so it slips before fitting the new gears. Then tighten it up so it only just grips enough to move the sunroof; that should prevent you from stripping a new set of gears immediately. Checking that the clutch is just on the point of slipping is a good thing to do every year or so IMHO, as a preventative measure.
Chrishazle
