I don't use my macan as much in summer as in winter - so n recent months it's been on a ctek trickle charger - usually green light on at the end of charge cycle and all fine. last week it was off entirely when I looked at it. hmmm.....
put the key in and it said 'low battery, go on a long drive'... so I reset the charger - ignition on, set it, two lights, charging all well....
then checked day after off again (charger is on the cigarette lighter socket near the gear lever which is supposed to be always on)
kept this reset, connect, looks ok, find out it doesn't a few days... clearly that socket had decided to stop being always on
then took it for a good hours drive, all well
plugged the charger in again, charging ok, green light fully charged day after - back to normal.
so what I think happened was .... for whatever reason ctek stopped or disconnected... then battery depleted... then when it was low enough the normal cigarette lighter connection would not stay on and kept disconnecting it. Maybe it only works when the battery is at a certain charge level, below which it tries to shut everything down?
anyway, all good now and I think the anomaly was due to the charger socket turning itself off due to lower battery level which prevented the ctek bringing it back up unless it was above a particular level.
lesson learned - check it a bit more often.
