Stereo wiring mess
Duffman502
After sorting some minor electrical faults i decided to tackle the stereo next and found this mess.
After a bit of searching i found a few threads but the wiring has been butchered in this one.
Does anyone have a colour code or wiring guide for these cars regards joe
Have you tried Clarkes garage mate? I'm not at home do cannot link but if you google it it's near the top. J
Here you go - 944 stereo wiring diagram
Most aftermarket radios etc have standard wiring as follows:
Wire Color
Wire Function
Yellow
12V Constant / Memory
Red
Switch / Accessory
Black
Ground
Blue
Antenna Remote
Blue with White Stripe
Amplifier Remote Turn-on
Orange with White Stripe
Dash Light Dimmer/Illumination
Green
Left Rear Speaker (+)
Green with Black Stripe
Left Rear Speaker (-)
White
Left Front Speaker (+)
White with Black Stripe
Left Front Speaker (-)
Purple
Right Rear Speaker (+)
Purple with Black Stripe
Right Rear Speaker (-)
Gray
Right Front Speaker (+)
Gray with Black Stripe
Right Front Speaker
None of those are factory wires . I suggest you also pull out the tray to have better access and look for the factory wires .
I didn't say they were. I said they are aftermarket colours now standardised so he needs to refer to the wiring diagram for the 944 (see the hyperlink at the top of my post) and connect accordingly - the original poster never said he was au fait with wiring so I was just adding information.
I was referring to the picture Paul ,had nothing to do with your post . Just saying that the OP should find the original wiring if he wants to clear out all that mess.
Here is a picture of my wiring for reference ,note all speaker wiring are color paired ,factory and aftermarket.
