Stereo changed - engine warning light now on
northo
Is this normal - engine warning light and oil level light both now on after a simple stereo change.
Any ideas?
Coincidence I'd say.
The S2 oil level sender is not above playing up and once it lights it stays on until you turn the ignition off - if it's faulty it usually stays off next time you start the car. If it stays on I'd say check the oil.
Already done - oil level is fine. A real coincidence that the fiddling with wires has seemingly affected these warning lights
I once did a stereo replacement on a vehicle(not porsche) and had various warning lights coming up and when I retraced my steps,found that there were stripped wire on the backing loom.When I taped them up everything was ok.This may be totally different but just thought I would share it.[8|]
