Hairyarse
I'm not sure if I have a steering issue or I'm simply not used to the 944 yet? When driving up the A1 last night, whilst holding the wheel straight the front of the car tends to tram-line and wander about a bit with the change of the road surface, just to the level that you're permanently "˜twitching' with the steering wheel all the time. Also for example when you pull back in to the inside lane after overtaking something, you're steering and moving to the left but the car may suddenly go straight or to the right a little, again I think due to the road surface. I guessed my tyres may have been over inflated when I picked the car up but it's the opposite, they were lacking a lot of air! I've pumped them up and gone for a spin and it's made no difference. I can't see anything wrong with the car as such, when parked up if you move the steering wheel the wheels turn instantly, there's no slop. Only 8k miles ago it had a full alignment check, tracking done, new shock absorbers, new tie rod and missing washers installed to front anti-roll bar. Also 24k miles ago it had a new steering shaft and rear suspension mounts so it seems all should be in order with the car. My BMW 330d has very sensitive steering and the run flats tend to tram-line a bit but I'm used to this now. Therefore, it's not like I'm used to driving something that's too "˜podgy' but this is just unexpected I suppose. Sorry for the long essay, but has anyone got any thoughts? Is this how 944's are or does something not sound right? All handling otherwise seems good. All comments appreciated Cheers Andy
