DavidL
I've thought for a couple of trips my steering was a bit odd. Quite loose in the straight on position but then it hits a stiff point either side on maybe 15 degrees angle.
It still works but it isn't very smooth. The heaviness seemed worse yesterday, caught me out a bit turning when moving slowly.
I don't seem to be loosing fluid lt is on and tension seem fine so any ideas?
I'm hoping its not hydraulic as the parts are getting a bit pricey. I wondered if it might be the UJ seized or similar?
David
David
