eddieedmo
Today I have driven about locally on a few small trips and all ok , the car has been running fine since last very irregular ( 4 times over 2 yrs ) occurence of overfuelling,erratic idle and misfire when starting from hot.I have not done anything to remedey except clean all connections to ICV , AFM ETC.
Went to local motor factors to get oil for my ladies car service and jumped in and started fine after normal 3 cranks and died instantly ,did this twice and on third attempt started fine and ran ok.
The tacho bounced as usual and fired but died as if plug had been pulled !
I think I have read this could be FPR causing very high fuel pressure and injectors been cut by ECU -is this a good start point to investigate.
Nick [
Nick [
