speedo change
- Thread starter Guest
Mrkjblue
Speedo just pulls straight out. if stiff than wrap a large screwdriver blade in electrical tape and lever out or can push from front luggage compartment if needed. then just swop over cables/rubber trim and push back in.
Can I ask what is wrong with the old one? I had mine apart last month for a few repairs.
I put the origional one in on friday and it still reads the wrong speed. I'm sure 4000rpm in 5th is more than 75mph! When I changed the speedo there was a red/black wire to one of the terminals which had split and I though this was the reason for the misreading, although repairing this made no difference. On the back of the speedo there are four terminals (ignoring the bulbs). The red/black wire goes to the one on the right, three browns go to the one on the left and a single brown goes to the second from the left. Should there be a wire to the 4th terminal hiding behind the dash somewhere?
Thanks,
Chris.
PS Bones, when I get this sorted you are welcome to the spare speedo. It is a bit rusty around the bezel and the mile counter does not work (although this may have been due to the split red/black wire). Pmail me with your adress and I'll send it to you when I've fixed this problem.
bones
As for the speedo reading out by so much ask Porsch-Apart if they calibrated the speedo, I doubt it as this is specialist work unless they sent it away. The speedo picks up pulses from a disk with magnets on in the gearbox. It is possible for these to drop a magnet I believe (though rare) Next item to replace is the sender, this is a fairly simple job but persevere with the clock I think that's where the problem is, I'll post later if I get into the garage today.
bones
Pos 1 (call this terminal Pos 1).
Pos 2 is another brown/red wire (pulse).
Pos 3 is a black wire.
Pos 4 is red/black wire and is the 12volt supply. I'll see if I can make some more sense of the wiring diagram now. The Haynes manual gives the best diagram of the instruments and senders I've seen but it still doesn't say show what goes where on the clock terminals. How is your clock wired?
bones
ORIGINAL: bones
At 4,000 in 5th you should be travelling at about 90mph.
Probably irrelevant but just for info, at 140km/h (84mph) I am only pulling 3200 revs, 4,000 for me is over the ton, also have checked the speedo with the GPS and it's only reading about 2% out (high).
Gearing probably different on the slushbox? Sorry, I mean Sportomatic [8D]
bones
