Spark Plug Tube 996 series
On the early 996 there is a tube which slides down the spark plug hole to keep the oil out it has a O Ring at the top and bottom which can easily be replaced
Later 996 (Probably .2) has done away with the tube and replaced it with a Rubber "Gasket" which fits on the bottom of the Rocker Cover on each plug "Hole" and an O ring at the top.
Does anybody know if the Rocker cover can be removed without removing the engine
THis is the same on the 997 Boxster which has the problem but nobody on the Boxster Forum seems to know
Thanks again
Thanks again
