Short shift kits
- Thread starter dugsud
bones
http://forums.pelicanparts.com/search.php?s=&action=showresults&searchid=854645&sortby=lastpost&sortorder=descending
bones
http://www.wevo.com/wevoshifter.htm
http://www.seinesystems.com/GateShift-1.htm
http://www.weltmeister.com/productslist.aspx?CategoryID=32&selection=6
http://shop.store.yahoo.com/eagleday/fashshkit.html
results then- the gear throw is deffinately shorter, i remmember having to lean forward out of my chair to get first and third before the mod. the gearstick is now less sloppy (down to new bushing probably). it is still not a patch on a modern gearbox but it is a deffinate improvement.
the way i figure it, you get most of the feed back from the car through the wheel gearstick and accelerator?brakepedal. for the sake of£80 including labour and VAT u change a major feedback component of the car for the better. it was definately money well spent!!!!!!!
hope that answers your question
ps i might now consider that devide that automatically centres the stick to the 3 and 4 gear plain. anyone out there have one fitted?
craig
Franck
Just like Craig, I have fitted a short shift myself as well. It is indeed aroud £40 and not very difficult to do. Just be careful to make sure that the part you will change is fiited/aligned exactly as the old one or you could get into small troubles with gear selection not being great. Best thing to do is to fit it, try the car to make sure it is all ok and then take the gear shift out again and weld the extension onto the stick so that it will stay there once and for all.
It is a definite improvement in terms of slack.
FM
jerry911sc
Jerry
jerry911sc
Obviously there are going to be different opinions and I stand by my previous post in this thread. However, FYI I found out today that there is another school of thought to the pro kit views in this thread. Namely that the short shift kit does not suit the 915, specifically that the synchromesh cannot be rushed and needs the time/ slower velocity the original slower change provided.
It gets worse, in that according to Dave prolonged use of a short shift kit increases wear to the gearbox(I think he said something about synchro rings that went over my head). This is said to be to the extent that when a box becomes worn and changes reluctantly: removing the short shift kit can bring about a noticeable improvement and defer the need for a rebuild!
If you haven't already got a kit the best one is supposed to be one made by Porsche. Again the story is that they didn't want to do it but felt that the market was producing inferior solutions or somesuch.
Apparently I am lucky in as much as my car has the porsche kit. But I have been advised in firm terms to remove it. I am reluctant because I personally find the shift very good compared to others, but I will be giving serious thought to changing back just to see if it is really an improvement and then deciding which way to go.
Jerry
Thats very useful info as I've not had time to do it yet. I'm having second thoughts anyway after reading various articles & your post just confirms what I've read.
The thing is, my 915 works fine as it is & as the saying goes....if it ain't broke, don't fix it. [
It might have a long throw but it works!
I would be very upset if I fitted a kit & the extra strain stuffed the gearbox so I'll probably leave it be.
Thanks for the advice.
Doug
jerry911sc
Glad you got the post in time. It would have been a bit of a blow to find out the possible downsides once you had installed a kit!
I will take mine off over the Winter (or as soon as I find an original shifter at an auto jumble or wherever) and report back on the difference.
Jerry
![Spanner1 [sm=spanner1.gif] [sm=spanner1.gif]](/forum/styles/default/pcgb/spanner1.gif)
